Use this procedure to modify the RESTCONF server settings.
These steps are considered optional and RESTCONF can operate with the default configuration of these values.
Use the data in the following table to modify the RESTCONF server settings.
| Variable | Value |
| enable | Enables or disables the RESTCONF server. The default is disabled. |
| tcp-port <1-49151> | Specifies the TCP port to use for the RESTCONF server. The default is 8080. |
| trap-notification | Enables or disables trap notification when the RESTCONF server is not available. The default is enabled. |
